Hey all. First off, thanks for any help in advance. Great board. Been a member for about 11 years and have gained a lot of knowledge. Thanks.
I've been troubleshooting an issue on my uncles boat and cant seem to figure this issue out. It will not get past 32-3300rpm. I've worked on motors since about the age of 10 (44 now) so i know enough to be dangerous
I'll list his boat specs and what we've done to try resolving his issue, without success... so far!
SPECS
1985 25ft Cat Limbo
Marine Power Vortec 350
Delco Voyager HEI Marine EST Ignition
Edelbrock Performer intake
Holley 4160 600cfm carb
Volvo Penta 190 Dual Prop
WORK DONE TO RESOLVE ISSUE
Rebuilt Vortec heads - compression on all cylinders right about 200psi
Rebuilt Holley carb
New HEI Ignition coil, module & pickup
New plugs, wires, cap & rotor
New exhaust manifolds & risers
This motor starts up immediately and sounds perfect. It will go beyond 3300rpm in neutral no problem. When we first dug into this issue, we checked timing - used the shunt, set it @ 10deg, removed shunt, increased RPM's and watched it advance to around 30-32deg - good, but didn't help. Then checked compression and found out there were a few cylinders low with one that was @ 70psi. Had the heads rebuilt, now all @ ~200psi - good, but didn't help. Checked fuel pressure @ carb while running WOT, 7psi. Checked throttle linkage for full range of motion - good. Checked manifold vacuum - good. Swapped out the Holley w/vacuum secondaries with known good Edelbrock 600cfm w/manual secondaries - no help. NOTE: The Holley secondaries aren't opening under full throttle for some reason which i'm thinking it needs to be rebuilt (possible bad secondaries diaphram) but i held the secondaries wide open while @ WOT and all it does is dump more fuel and growl a little deeper. When we swapped it out with the Edelbrock w/manual secondaries, it did the same thing so i've ruled out the carb being the cause of the issue. Maybe the vacuum secondaries on the Holley would open up if the RPM's went a little higher? Not sure but not concerned much about that right now since more fuel doesn't help our situation! lol. Also, it does get to 3300rpms without the secondaries opening but again, with them wide open and more fuel dumping, hardly any increase in power. Feels like we're dragging the trailer. Yes, i've checked, there is no trailer attached under boat
So figuring that now we know it's getting fuel, has good compression, the only thing left is spark. Replaced the plugs (gapped @ .40)cap, rotor & wires, all HEI. No help. Made sure the coil was getting a good 12v. Decided to replace the ignition coil, module and the pickup last night just in case they were acting up under load. Took it for a run in the bay, still... only 32-3300rpm @ about 30mph (GPS). Unfortunetly, i don't have the prop size/pitch but my uncle has assured me that this boat ran up to 46-4800rpm with the prop that's currently on it. It has never been re-pitched and there are no visible signs of damage.
So... the only thing left we can come up with is that possibly the outdrive is causing the problem. It does vibrate a bit when under load and a bit more when WOT. We're thinking maybe the gimble bearing, ujoints or maybe even gear bind? Not even sure if any of these would hold it back from reaching proper RPM? Anyone experience this as a cause of limited RPM?
Any advice, info, suggestions would be greatly appreciated. I'm at a loss at this point and fully frustrated but will not give up!
THANKS! - Jersey
SPECS
1985 25ft Cat Limbo
Rebuilt Holley carb
THANKS! - Jersey
