Re: Vortec Roller Upgrade
"Do you think this will get me over 60mph"
Probably not over, but closer.
The 325hp rating is probably at the crank, vs prop. So, probably 300hp at prop. If carbed, they would probably be running a stouter cam that stock Merc roller. Exhaust upgrade, maybe another 5%. So at the prop, you are talking about 50-65HP increase over current mag. A very rough rule of thumb of 10hp per mph, gets you close, but will depend on your hull. Also the rough rule doesn't stay linear! especially as you hit higher speeds.
PS: Another factor to consider is that most crate engines are dynoed with headers or dual open exhaust. This inflates the hp rating when put in a boat. For a stock like engine, probably only by 10%.
PSS: Building a 383 SB "should" be able to push over that threashold. You would probably want to visit some of the "go fast" boat forums, to confirm others with your hull acheived that milestone.
