stu man do
- Joined
- Aug 2, 2008
- 29
At my wits end, having issues with one engine not reaching wot. Best it will do is 3800 rpms under load, trimmed down. The other engine will do 4400 rpms. I have done a turn up(cap, rotor, plugs), had codes read by marina mechanic, only code was low oil switch. Would this cause an rpm loss? They got the code to clear by wiggling the wire to sensor/switch.
I have added sea foam, injector cleaner, cleaned air filter, replaced gas filter. It is like I do not have the last 1/4 throttle on the one side. The engine scan proved spark advance is right, so anything I am missing?
I checked the TBI and the butterfly is wide open, measured the throttle linkage and same as other engine.
Went through Don's list, no prop changes, clean hull, etc.
I plan to have the fuel pump pressure tested this week.
The engine idles fine, and sounds perfect.
If there was an exhaust blockage (this engine does not have the flapper) where would it be, outdrive? I am asking because I did have an impeller go bad, never overheated, just lost a few fins. I have found most of them in the thermostat housing.
2000 VP PEFS TBI SX-M Drive 2660 Regal
Thanks
Thanks
