Gents I have lurking for some time absorbing all of the great advice but now i have a problem i need help with. I have a 2000 sea swirl striper 2600 with a VP 5.7 gsipwtr. My problem is that my starboard riser is getting hot. Back story is the boat was dry stored for about 7 years before i took ownership. I have been going through it to make her ready to fish tuna this season. I have pulled the risers and manifolds. They both had a lil wear but cleaned up nicely. I have replaced all of the hoses as they were in bad shape. a new thermostat housing, thermostat, temp sender, and impeller were installed. While running the boat on the muffs the starboard riser was getting hot and started to smoke a little. So i replaced the starboard riser, after running it again on the muffs, it still is hot to the touch. i can place my hand on it for about 4-6 sec. The port riser and manifold run ice cold. Also the starboard manifold runs nice and cool. My boat does not have flappers in the y pipe so I assume there is no blockage from a damaged flapper. The impeller I took off was complete so i assume there are no broken pieces lodged anywhere. I have taken each hose that supply the manifolds off one at a time while hooked to the muffs and each hose flows water equally. I have heard that the starboard side runs a little hotter than the port based on the flow design. but I feel that Im still to hot. I haven't shot it with an IR gun yet but plan to in the next few days to get an actual reading. My temp gauge read 170 degrees. Is there a chance that the starboard manifold may be occluded in such a way that it cools appropriately but doesn't allow the brand new riser enough water? My thoughts are that if it has a blockage that the water might be forced to the port side... the supply hose to the starboard side is not ridged or pressurized in any way... A test I might try is while the engine is off, to pull the supply hose off the starboard manifold and flow water into it via a garden hose. Is there any chance that my valves or piston could be subject to damage? Im a lil lost hear fellas. any thoughts are greatly appreciated. thanks dustin
