VP 5.7 GXi FUSE BOX - FUEL PUMP RELAY
GPC
Hello;
I am not getting power to the fuel pump. I located the fuse box under the engine cover and check the fuse # 7 (fuel pump) - is OK and now I am trying to locate the relay for the fuel pump.
There are 1 big relay (G8W-1CT7-R-DC12 - ignition) and 3 small relays ( G8V-1CT7-R-DC12)... Does anyone has a components layout for the fuse box or can show me which relay controls the pump?
I have not been able to locate any indication in the manuals...
Please see attached photos for reference.
Thanks for the help
GP
the large 30 amp relay is a standard sealed VF4 relay with diode suppression. the smaller 5 amp relays are micro ISO 280 relays
there are troubleshooting guides in the factory manual. http://boatinfo.no/lib/library.html
BlastoFriz
The fuel pump relay is the smaller relay just above the spare fuses row. The small relay on the left of the spare fuses is a spare relay. If I remember correctly, once I pulled the relays, there was labeling underneath them.
89retta
Have you checked to make sure your tether is attached all the way. I just had the same problem a few weeks ago and it turned out to be my tether. It was still on but had come off enough to kill power to the fuel pump.
