AList233
- Joined
- Apr 2, 2011
- 46
Looking for a little guidance. My '84 Albemarle has been out of commission for the last 5 yrs. due to a much needed overhaul. All wiring was needing replaced as well as the outdrive needing resealed/refinished.
I replaced the motor harness on the 95' VP 5.7L PHUS TPI with a good used harness. The old harness was totally trashed. I went over the used harness, repairing all questionable wiring. Everything tested good that I was able to meter with the exception of the ECU.
This weekend, I changed oil, plugs and fuel/water separators. I can get the motor to run by pouring gas in the throttle body, but dies immediately. I have confirmed that both fuel pumps are cycling and used a separate fuel source to attempt to get it running.
How can I confirm that the injectors are firing? Or could the injectors be clogged due to the length of time the boat sat with old fuel?
Thanks in advance for any help
