vp aqad41a
vince59
I want to check if the rpm gauges are working properly. What kind of instrument do I need and how do I connect it to the engine?
Re: vp aqad41a
hand held optical tach
you can even rent them, or borrow them from AutoZone.
vince59
Re: vp aqad41a
Ok I believe it is the same used for car's engine...am I right? How to connect?
Re: vp aqad41a
its hand held. you put a reflective tape on the front damper pulley. works on any rotating equipment. you do not connect it.
on gasoline engines, the tachometers are triggered off of the ignition system. diesel engines are triggered off of either the alternator, a mag pickup, or a reluctor ring.
