VP Fogging mixture
cw_racefan
Anyone have the "recipe" for Volvo's recommended fogging mixture for an EFI? Have seen a couple different mixtures, wasn't sure what VP recommended.<br /><br />Thanks!<br />Craig
Don S
Re: VP Fogging mixture
This is from the latest service manual.<br /><br />In addition to stabilization of the fuel, it is highly desirable to have the<br />valves and cylinders coated with a light film of oil previously accomplished<br />through fogging. Today’s fuel injection manifolds are designed<br />with a complex air channel design that will not allow the traditional fogging<br />oils to be injected past the throttle plate while running. The oil will get stuck in the plenum and never reach the cylinders. Together with<br />the stabilizer, two-cycle motor oil can be added to a fuel mixture for<br />stabilization purposes.<br />• Using an outboard motor six-gallon fuel tank, add two-cycle<br />motor oil at a ratio of 50:1 (one pint to 6 gallons) and stabilizer<br />at one ounce per gallon (unless stated otherwise on the manufacturers<br />label). Mix well.<br />• Disconnect boat fuel line at engine fuel pump. Attach the storage<br />mixture fuel tank.<br />• Connect a suitable engine flush device if the boat is not in the<br />water.<br />• Run the engine on the storage mixture for approximately 5 minutes<br />at 1500 RPM. This will ensure that all fuel system and<br />internal engine components are thoroughly protected. Do not<br />operate the engine above 1500 RPM as the water pump<br />demand may exceed the supply, damaging the pump.<br />• Reduce the engine speed to idle and stop the engine.<br />• Reconnect the fuel fitting and check for fuel leaks.
Chris1956
I saw another way to fog an I/O on a boating show the other day. According to the show's expert, Mercury recommended putting 2 oz Standard TCW-3 2-cycle oil into the fuel/water seperator, installing the seperator and running the motor long enough to burn the contents of the seperator. I figure that is about 2 oz oil to 32 oz gas.
Scaaty
I still have 50 some gallons in my big boat that I will pump out and use in my van. I'm putting new manifolds on, only I have a carb, so no problem...BUT I will STABIL the gas in my external filter /separator, and run that into the carb, as the boat will sit until next July
