Boat info:
Larson 190 LXI
Currently second owner.
Approx 338 hrs. total usage
2002 4.3 GL-A 4012069029
Transom Assm. TSK SX-M 3868844
Stern Drive: SX-M
Ratio 1.79
Prod. No. 3868893
During my yearly maintenance I discovered approx. 4 oz.
of water in my outdrive oil. Obviously not good.
Since the outdrive was off the transom and on my
homemade stand,(thanks to all the designers here),
I separated the upper and the lower units from each other.
I replaced the 2 obvious O-Rings on the lower unit per
the manual,(again thanks Don for the manuals),set up a
low pressure test and had pressure loss within 30
seconds.
Seeing that I broke out the soapy water and sprayed the
entire outdrive and then tried to repressurize the
outdrive to 3-5 psi.
During that attempt of pressurization the prop shaft and
seal resembled the "Lawrence Welk Bubble Machine".
With this being the obvious leak of oil and intrusion of
water into the outdrive, is this a DIY repair?
The only part of this repair which seems to be
problematic is setting the prop shaft seal without VP's
special tool.
Please correct me if I'm in error or if there is a
better DIY procedure to repair this lower unit prop shaft seal.
Any or all comments are welcome.
I'm here to learn more.
Larson 190 LXI
Stern Drive: SX-M
Ratio 1.79
Prod. No. 3868893
seconds.
special tool.
