AList233
- Joined
- Apr 2, 2011
- 46
I am in the process of cleaning up the motor bay on my '84 24 Express that has the VP 280 DP/PT drive. This drive does not utilize the tilt motor, just twin cylinders for tilt and trim.
Unfortunately while servicing the trim pump, both the hydraulic lines at the bottom of the pump were so corroded they broke off. So I went ahead and pulled the pump to access the fittings.
Both the relays are in pretty bad shape and it looks like they are nothing more than Ford starter solenoids. I am looking to replace them while everything is apart.
Will a standard 12V starter solenoid work?
