Re: VRO 1993 V6 Johnson 150 hp
silverharley,The VRO pump on your engine is pretty reliable as long as one pays attention to a few basic things.Oil level in reservoir,oil hose condition and connections,oil reservoir tank vent,fuel line condition and connections,and insure seasonally that there is no accumulated moisture in oil reservoir.While your VRO pump has fuel restriction and oil flow alarms within it they are not a failsafe mechanism.The question of whether to disconnect or not is a topic that is sure to stir emotions and I will bail out on this one.A new unit sells for around $250 and a rebuild kit That comes with parts to rebuild the fuel side and air motor sells for around $60 bucks.If your VRO is working presently there is no need to rebuild or replace.If you do decide to defeat the VRO and mix 50:1 the VRO works just fine as a conventional pump after the oil inlet is capped and the alarms are disconnected.
