CadillacsCowgirl
- Joined
- May 9, 2012
- 101
We just filled the tank this week and are now all the sudden getting a no oil alarm only at low speed. Any ideas???
There is a white/clear plastic tube at the end of the VRO hose line under the cowling. If is somewhat transparent so that you can see if you have oil moving through it direct to the side of the pump. When you prime the oil hose, you should see oil flow through that sight device and then out of the end of the hose. Then reconnect immed. to the side of the pump. You might check to make sure the oil hose is not bad. They do get stiff with age. Those oil hoses are not the same as the fuel hoses-different part numbers.
Thanks mate. I found and bled the air in the hose. Then checked the oil flow, oil hose and kinks. They are all good. Ran the motor at 800rpm for 5 minutes then another 7 minutes at 1500rpm on muff, the alarm didn't go off. I will run the motor again tomorrow. See if any air sneak in overnight.
