Re: vro disconnect
disconnect the plug on the sending unit on the oil tank. disconnect the harness going to the fuel pump. cut the oil line, and plug it so there is not air leak. premix you fuel, and disconnect the fuel like at the carbs, and pump the primer bulb, until you get gas that is colored like the oil. usually blue tint. reconnect carbs.
