VRO Leaking Fuel
crane-hawk
I replaced some fuel lines and a fuel filter on my 1991 Johnson 90hp VRO. I primed the system and as I was doing so I noticed fuel leaking from the two halves of the fuel side of the VRO pump. I took the VRO apart and can see no obivious reason for failure. Is there supposed to be a gasket or o-ring between the two halves of the fuel pump because I did not have one. The fuel diaphram has some cracking on the underside of the "skirt" but has not broken through. Can I rebuild the VRO or is it time to convert to premix? What is most cost effective? If I convert, what is the part number for a standard fuel pump?
kenmyfam
