This is a 1990 200 HP - J200TXESM - that is running well.
If there's a way to search for this, I have no idea how. Thanks for a pointer to the information or any help you can give.
Are there specifications for the distance from the engine and the height (relative to fuel pump) that I can install my oil tank? Right now it's located in the rear of the boat near the engine and about 2 feet below the fuel pump, total oil line run of maybe 3-4 feet. For the functioning of the system, it's probably an excellent spot. But, it's in a location where it is kind of in the way and at risk of being bumped by feet (when fishing) and also coolers, etc. if they slide around or are carelessly moved.
I'd like to move it forward as far as possible (where I can tuck it into an unused little niche which is also more protected). Rise to fuel pump would remain at about 2 feet.
Another option might be to use the same general location, but get it off the floor to a spot that is about at the same level as the fuel pump and maybe 2-3 feet away.
I'm installing a new/current model of fuel pump and while I'm at it I thought I'd maybe change the location of the oil tank.
I do have a factory shop manual, but forgot to see if this information is in it (and now I'd like to buy oil line before I head home this evening).
Thanks for your help.
