vro primer bulb
jerkoz
should the primer bulb on the vro oil line be as soft as the gas line bulb
Rick.
Mine has always seemed quite hard. 1995 40hp. You have to be very careful pumping it as you can easily fill the carbs with oil. I always start the season with a 50/1 mix in the tank until I've verified the oil in the tank is depleting.
Joe Reeves
No.... The oil primer bulb, once it's been primed properly at the engine (as follows) should "always" be hard as a rock.
If you can compress it as you would the fuel primer bulb, it contains air... in which case, prime it.
(Priming The VRO Pump)
(J. Reeves)
When hooking up or installing a VRO whether it is a new or original VRO pump, it must be primed in order to dispel any air that might be in the oil line.
Have the Oil line attached to the engine fitting BUT detached from the VRO. Add a piece of fuel hose if necessary to the oil line so that it can be aimed into some sort of container.
Pump the oil primer bulb, catching the oil flowing out of the line into the container until you are absolutely sure that you have rid the oil line of every bit of air that might have been trapped there.
Now, connect the oil line to the VRO and secure it. When the oil line is secured, apply pressure to the oil primer bulb ONE TIME only. That's it.
jerkoz
it always is hard as a rock. it just had me worried. thanks to all that replied
Rick.
Well I learned something today! Thank you Joe. I'll do that from now on.
jimmbo
How old is it? Normally it is Firm when it has done it's job priming the system. Once the oil pump is pulling oil thru it will no longer be Rock Hard
jakedaawg
I will only add this...the bulb is for the mechanic, not the owner. It is used to prime the system and should not need to be touched unless you run out of oil. If you do run out mix your gas at 50:1 and visit a mechanic.
Joe Reeves
And that's the way it should be. The rules pertaining to oil differ from the rules of gasoline. Why??......
Beats the Hell outta me! :)
