I have fuel leaking at the top of the VRO pump. 88 Johnson J40ELCCS on the Lund I just bought. There is a 1/2" dia round black tab that bubbles/fuel leak out of. Pumps are $350. It idles ok but dies when I put it in gear. Seems to lose pressure at the bulb. Should I disconnect the VRO and go to premix. Does the VRO then become the fuel pump? If so, will I still have the leak. Did a search and it seems to be to best thing is to get rid of the VRO. Also a little fuel spitting out of the top carb. Maybe bowl is full and inlets are clogged? Thanks in advance.
Can the leak be Fixed?
