had a mechanic look at my "link & synch" the other day,got that straightened out. while running it in his test tank he said the amount of smoke being discharged at idle speed was an indicator that my VRO pump is on the verge of going out. It was replaced about 3 years ago - other than that, never had a problem with it.
Question #1 - is excess smoke at idle speed an indicator of this?
Quesiton #2 - if I decide to be proactive and bypass the VRO are the steps as follows:
1) Disconnect the oil line - see photo - looks like I could cut this line, insert a Plug into the line going into the VRO pump to seal it off, then remove the remaining oil line from the motor
2) Disconnect the VRO Sensor Plug - see photo - do I just unpug this and tape it off?
3) DO NOT FORGET TO RUN PRE-MIX!!
4) to be safe, disconnect the gas line at the motor filter, pump gas from the line into a container until I see the pre-mix gas flowing, then connect it back
5) DO NOT FORGET TO RUN PRE-MIX
6) Disconnect the wires to the oil tank when I remove it from the boat
I have read in some places that you need to replace the pump with a gas only fuel pump or replace with a manual fuel pump - is this necessary?
