Vro pump needs replacing
muskrat
I have a e70tlen,can you install the standand fuel pump back on this motor with out to much trouble.And what model should i look at for parts...
tashasdaddy
Re: Vro pump needs replacing
1992 sure, you disconnect the wires on oil tank, disconncect hose and tank, disconnect wires on vro pump, remove pump. and install a 3 line fuel pump. #385784 superceded to 438559
muskrat
Whats the difference between 438557 and 438559 thanks
tashasdaddy
438559 is the 3 line fuel pump, that uses the pulse line from the vro pump, to activate it. makes for easier install. i believe 483557 mounts to the block and used the boss fitting to activate the pulse for the pump. some newer motor do not have the boss fitting.
muskrat
Iwill have to look alittle deeper they both are pulse drive by hose.
