vro to fuel pump
markrose
? where does the fuel pump get its crankcase pressure from on a 150 jon 1991. there are two brass plugs near the starter is one of these where the fuel pump would get its pressure had a vro before i purchased it no pump on it at all now.
Dhadley
Re: vro to fuel pump
We assume you have a crossflow, right?
Dhadley
If you use the oil injection pump you'll use one of those ports to get the pulse. If you use the old style "standard" pumps, you'll need 2 and use both ports.<br /><br />If you use the oil injection pump you can still premix amd just not use the oil side. Personally I'd use the oil injection.
markrose
can i use a electric fuel pump from an auto parts store as long as it not more than 6psi. can i just wire it into ny ignition.
rolmops
You can but it is not safe,because in case of engine stalling the fuel pump would still be pushing fuel and in case of an engine fire that would be a real bad idea.
