greens1098
- Joined
- May 20, 2012
- 9
Okay, Ive searched this and cant seem to find the correct answer. I have a 1986 Evinrude 150 with a VRO pump on it. Well the fitting on the top of the pump is broke and the bracket that has the screw in it that hold the fittings are stripped out. Well I ordered a VRO2 from a 1994 Johnson 200 for parts. Well looking further into it I see that people are converting the VRO to VRO2. If it is a easy process without buying that kit then Ill do it but if not Ill just use the parts off of the VRO2 to fix my VRO up. Any advice and input would be greatly apprectiated.
Drew
Drew
