hotshot123
- Joined
- Jul 9, 2009
- 98
ok, here is the short of it. someone gave me an old robalo center console that needs some work. it has a 1987 225 rude on it and it has not been cranked in a couple of years. he said it ran good before his granson got hold of it so he was not sure what the deal was. I took the plugs out and squrted the cylinder with sea foam and spun it over. then i did a compression check ,all good. I got a plastic tank and hooked up to it and sprayed the carbs with seafoam not knowing what to expect. as soon as i touched it it started fine and idled for about five min with the muffs on. i shut it down and looked things over good then unhooked the gas line sprayed carbs with sea foam again, then fired it and idled the fuel out of the carbs. after that i was poking around and realized that the vro was unplugged. GRRRRRRR . I cant belive i missed that the first time.
Do yall think i hurt it bad since it had no oil in the gas? i guess the smoke i was seeing was from the sea foam in the cylinders and carbs. it may have ran between 5 and 10 min total and never came off idle
