I have a motor that I'm slowly putting together (Winter project). It's a 1989 150 crossflow. I bought a used pump on ebay from a scrapped motor. Supposedly it works. I can't make it work... Is there any way to test this pump? Also, if it's not working, should I buy the rebuild kit for the vro or just go with the old two pump system? What would be the least expensive way to go? I don't intend on using the oil injection. Thank you
