vro2 pump
DRFTWD
does anybody know what the pressure and vacuum is to operate the pump? I have a vro2 pump on an evinrude 200, model VE200SLEID, The pump has been rebuilt and passes the bench checks.
clanton
Where are you checking tis vacuum and pressure? Fuel pressure 3 lbs. at idle.
DRFTWD
Tested per flo chart for vro pump. Also checkedl output pressure.passed all these tests. Trying to measure the pressure/vacuum cycle to determine if the problem lies there, Thining bad crank seal or reed for the driving cylinder.
Faztbullet
Worn skirts on piston will also cause this as crankcase pressure is to low to overcome spring in air motor. Will run on top end but will run out of fuel at idle...
