John from Madison CT
- Joined
- Oct 14, 2001
- 176
Rodbolt and Ray: I am about to reinstall my VST tank on my '98 Yamaha 250hp Ox66. It is all back together with new filter and gasket.<br /><br />I am about to remount her on the engine, but a few things I was wondering about:<br /><br />1. With no oil in the VST, if I just pump the primer bulb to refill the VST, won't I put in just straight gas with no oil, as the engine needs to turn the gear driven oil pump to mix in the proper amount of oil?<br /><br />2. Should I just crank the engine with the kill switch pulled so I have no spark to fill it?<br /><br />3. Does the VST pump run with the kill switch pulled?<br /><br />4. How do you recommend I refill her safely so that the proper oil/gas ratio is delivered to the injectors?<br /><br /><br />Thanks,<br /><br /><br />John from Madison, CT
