I have a mercury 150 efi on which i have bypassed the ECU fuel pump driver via the purple wire and keyed relay kit. Motor ran okay but started a little rough and would not idle in the water without adding a bit of throttle.
after a frustrating, if not dangerous day on the water, i neglected to turn off the key switch at the ramp and put the boat away with the VST running continuously for about an hour. engine smelled like fuel and the VST itself was VERY hot. The primer bulb was soft too, possibly indicating an empty VST. Is the VST pump toast? the motor still runs but I haven't run it on the water yet.
thinking now that a ECU rebuild was the better(but much more expensive) way to go.
