W.O.T. question??
billgabbert1
So read a lot on here and have been noticing people talk about their max rpm or W.O.T. I have a 75 Glastron with a aq170a and a 270 out drive and now have it running pretty good but when I?m out I don?t run it over 3,000 rpm should I run it at W.O.T.? my thinking is fuel economy and longevity of the motor?
UpperUpsilon
Re: W.O.T. question??
Yeah, running at WOT for extended periods of time is bad for the motor, and its also a waste of fuel. However, knowing that your motor runs well up there and has the correct prop setup is important for motor longevity/peak performance.
sethjon
WOT is ok sometimes, but your thinking is right on. Unless you're taking someone in for an emergency why push it. 75-80% is more than enough.
