oldslowandugly
- Joined
- May 12, 2010
- 98
On a friend's boat the Teleflex tach quit, so he bought a new one and it wouldn't work either. I tested the old tach and it still worked fine. So I checked the wiring and found a probable tach signal wire break in the main engine harness as it exits the motor (1982 Evinrude 35 hp). Twisting and bending the harness made the tach work/fail. I suggested rather than opening the harness, just wiring in a new tach wire from the motor to the dash just to get through the season and he agreed that made sense. After that was done the tach works but the needle wanders and never seems to be reading exactly where it should. I inspected his job and noticed that he wound the new tach signal wire around the engine harness about 20 times, rather than tie-wrapping it in place. The battery cables are also inside this harness and I seem to remember that is a no-no as it introduces RFI which screws up the tach reading. Am I correct and will straightening out the wiring path solve this?
