soonerdeer123
- Joined
- Jun 18, 2013
- 5
First of all, I'd like to say this is my first post on this forum, I've been googling boat things and I always get directed to iboats for my answers so I figured it's time to join !!!
I just ordered a Big Air Vapor wake tower for my 04 Glastron GX205 and I have a question about the install, mainly about the backing plates.. I know after reading for hours on the internet that I need to make wood backing plates for the inside of the hull to strengthen the mounts.. So yesterday I looked up in the hull where I will be mounting the tower and I see a bunch of spray in foam near the area I would be putting the wood plates, I know most folks say I need to use an epoxy between the wood and the hull to fill any voids or gaps, but can I use this spray foam as my filler ??? I would have to use a paddle bit on a drill to make it flat for the wood to butt up to but is this a strong enough material ? Or should I use the paddle bit and get all that spray foam out of there and get down to the fiberglass and use the epoxy as others have mentioned ??? I was thinking this foam would be a better option but not real sure what I'd use to bond the wood to this foam.... Any advice is appreciated !!!
