I am going to make a few changes on a 50 hr, 350 that I have. It is a low HP version with the following specs.
crankshaft type - reground/polished cast crank
piston type - Sealed Power cast/dish pistons -16cc
camshaft specs -
intake duration is 202 @ 50
exhaust duration is 212 @ 50
intake lobelift is 262
exhaust lobelift is 272
110 degree lobe seperation
valve specs - 1.94 (intake) + 1.50 (exhaust)
compression ratio - 8:1
I am going to change a few parts with some extras I have laying around.
For the heads I have a set of assembled bowtie vortec small port heads. For the cam I have a compcam XM256H. I will put a vortec bowtie dual plane intake and top it off with a Qjet.
So essentially i am changing the cam, heads and intake. It pains me to use the dish pistons, but I don't want to put much money into it.
Should wake it up a little with some good manners.
It is going to go into a 17' Double Eagle deep V.
camshaft specs -
