Walleyehed - any numbers on the Solas Rubex alu?
stevens
Hi Kenny,
I've noticed that the new Solas Alu Rubex prop has made an impression on you:
...I Tested a new Solas Rubex 3-blade and was VERY impressed with the over-all performance of this aluminum prop-one of the best I have ran, in fact.
...take a look at the Solas Rubex props here at iboats....I'm flat-out impressed with them and I run a ton of props.
...the new Solas Rubex...it's quite a prop for the money.
As a result, I have ordered a 17P to have as a spare in addition to the 17P Enertia I usually run (on an Uttern D66 22 ft. daycruiser powered by a 200HP Verado).
Now, you wouldn't have any numbers to post for the Rubex alu prop, comparing it to the other prop test results posted at the top of this forum?
I'd fully understand if you cannot post the numbers, but it would be very interesting to see. I'm especially interested in seeing how it compares with a same pitch Black Max, a Stiletto and an Enertia.
Thanks.
