Rudy Brown
- Joined
- Apr 3, 2005
- 289
On my 84 16ft bass boat, I finally got around to lifting the motor to the 4th(highest) hole. I didnt find to many R's between the 2nd and 3rd hole. (2nd 5k vs 3rd 5200) If the 4th hole is too high, what is my next step in getting the rpm's up? Prop now is OMC 13.25 X 19 SS. Should I really be looking at a turbo 13.25 X17 SS? And since I lost a little water pressure (still 20 psi @ wot) I'm assuming I'll lose more now in the 4th hole. How do I block off the upper hole and will the lower 3 be enough. Or at what PSI do I need to block off the hole/ safe to run at wot? Oh, one more, what causes the rooster tail on fast boats? The prop running on the surface of the water? Thanks.
