Walleyhed-????
KCLOST
I was looking over your post that shows all the prop test results and noticed that one of the props had a note that pointed out good lift...<br /><br />In particular it was the Tempest prop 23 pitch...<br />Was that the case only with that pitch or did you also see good lift with the 26P Tempest you also tested?<br />Curious..
walleyehed
Re: Walleyhed-????
The tempest had good lift in all pitches...it seems like the lower pitches have less and less, but the Tempest held fairly consistant on that.
