Re: Want better performance
Test compression, perform an engine decarbonizing, carburettor rebuild if you haven't already done this and finally replace the spark plugs with the correct type.<br /><br />If your motor is within the recommended range perhaps 4,700 rpms of the 4,500 to 5,500 rpms, then I would increase the propeller pitch 1" to increase rpms' by 500 this would put you in the top part of the range and improve your hole shot.<br /><br />Also remember that every 1,000 feet of altitude increase will lower your power 10%. Also hot and humid days will decrease power by reducing air pressure. Therefore, playing with propeller pitch and carburettor adjustments is the way to go.
