Re: Want to add visual alarm to Yamaha engine
I don't know anything specific to the yamaha's, but on my Johnson, the temp warning horn was too quiet as well.. so I did what anyone would do in that situation.. I replaced the mini horn with a $8.00 relay, and use the relay to power a full size car horn in the dashboard..<br /><br />You can't miss this thing when it goes off. its deafining in the cockpit and drowns out my old Johnson 100HP completely.. best of all, because of the relay, the power drawn through the OB harness is less then it was with the mini horn..<br /><br />I also took the liberty to hook it up to a dash light.. just in case the horn fails for some reason. Since I'm using a relay, I could use any 12 volt light I wanted since the power is not drawn from the outboards harness at all, only the relays lightweight coil is run from the harness..<br /><br />Its been great for me, as an added bonus, I put a horn switch on the dash and now I can get the attention of PWC users so they can see me give them the finger for speeding in the no wake zones.<br />
<br /><br />regards<br /><br />Franki
