phoodieman
- Joined
- Oct 18, 2010
- 42
1967 RDSL-29 40 HP Johnson.
I have water in the lower gear case. I have the lower unit off so I want to change every seal as this older motor has probably not been serviced in 20 years. I recognize most of the seals but not all. As I see it, these are the places water can get in that I know of. 1. The drain/fill plugs. 2. The oil seal at the prop. 3. The drive shaft seal. 4. The spaghetti seal at the skeg. (I'm probably missing some). Will this kit take care of any leaks. (Assuming all the infrastructure is sound).
phoodieman
phoodieman
