Re: Want to gain a little
If my figures are right,assuming a 1.85 gear ratio,your figures are optimistic.
I have you for 34 mph at 10% slip. Is your speed by gps?
correction,My following calculations were way off::
Again if my figures are right a 12" prop @ 6000 rpm at 10% slip would be about 33 mph.corrected
But I doubt the prop change would make up 700 rpm.
At 5700 a 12 would make about 31 corrected. Of course all these figure are approximate.
You might check the height of your motor usually the antivent plate(just above the prop)
should be about an inch above the bottom.
This could net a couple of mph under ideal conditions.
Prop change from al to ss is unpredictable I have seen poorer performance initially at rare times
so more than one selection may be necessary. Some dealers will do exchanges with the agreement you will buy the correct prop.Usually requires a hefty deposit.
