Re: Want to swap carbed powerhead onto 150 FICHT? Compatability??
I have studied this in reverse...putting a Ficht powerhead on an older leg. I will call it a leg for convenience.
I ditched the effort by the way, when finding out about the problems that Ficht motors have.
But, define the leg as...lower unit, midsection, exhaust adapter assembly.
I found that the exhaust adapter will have to be changed also. The Ficht exhaust adapter is different from the say...1994 thru 1999 carbed V6 loopers.
But if you examine very carefully the parts lists at BRP's website, comparing the midsection part numbers, gasket part numbers, etc., I think you will find that a mid '90s V6 looper powerhead AND associated exhaust adapter will fit onto a '98 Ficht midsection.
Don't take this to the bank....but I feel fairly confident that what I am saying is correct. Good luck.
Here is the link to BRP's parts list:
http://epc.brp.com/login.aspx?Retur...&lang=E&brands=skidoo,seadoo,atv,sportboat,ej
