Re: Wanted: Repair manual 1988 Johnson 110hp
I would suggest you get the OEM manual since it will cover your motor specifically. The aftermarket manuals seem to be too general usually covering a wide range of motors. I looked for a manual the same as you and bought a Clymer's but then soon after ended up buying the OEM from Ken Cook anyway. Guess what, the Clymer's I have doesn't even look dirty or used.<br /><br />Go to your local library and look at one before you buy it. Sure, many of the libraries won't let you check out reference books but it gives you the chance to try before you buy. The library may in fact have a couple of books from diferent publishers.<br /><br />The (often times) lack of information from a third party (aftermarket) book and the headaches caused from it is not worth the ten dollars saved.
