Re: Wanting to check Mariner overheat alarm
Back from the woods.
On the starboard side, above the switchbox mounting plate is a 2 screw terminal strip. One wire is purple, which used to be power to the oil alert module. The other is tan, which is the alarm circuit. Ground that screw and the buzzer should sound. There should be a wire going from that screw to the overtemp switch on one of the heads.
hope it helps
john
