I'm new to the forum, so I'm looking for a little help. I have a 2005 Merc. 40 horse 2 stroke 2 cylinder outboard that is causing me a little heartburn. I was having trouble with the motor dying at idle last year. I rebuilt the carburetor, and it took care of that issue. However, I took the boat out on the water and had a different issue this weekend. I idled the boat out of the marina, and things seemed to be working fine. As I hit the open water, I throttled up to a plane and the motor ran good for about three or four minutes. Then it just shut down just like it ran out of gas. I was able to restart the motor, but I could not throttle up. I could only keep it running at just above an idle and limped my way back to the dock. After getting the boat home, I hooked it up to the flaps and it fired right up. I let it run at about half throttle for a while, and it shut down again. Before I start throwing money at a fix, I'm just hoping someone can tell me I'm on the right track. I would imagine there is something wrong with the fuel delivery, so my first course of action is to inspect all fuel lines leading from the tank to the carb to check for any debris or air leaks as well as replacing the fuel filter. However, if I find nothing there I am not sure what order I should check things. Guessing the fuel pump then coil. Although, I am obviously getting spark since the motor will run at low speeds when I experience this shut down. Am I on the right track? Ideas?
