Hello all again from Australia,
Once again I am seeking knowledge from more learned persons than myself. I have a 2006 tahoe q4 ski fish with a standard 4.3l mercruiser carby with alpha 1 gen 2. Sorry I don't have the actual serial numbers as the easy access sticker has gone blank and I don't know where to look to find them.
My problem only started today when I was out fishing with mates. My boat is mostly used in salt water but always flushed at home everytime. Today at the boat ramp after loading back on the trailer I then pulled the bung and then was shocked to see a constant strong flow of very warm water for the next 5 mins. My whole bilge must have been full without my knowledge. While fishing I saw that the motor was performing great as usual and running at normal temp as I'm paranoid re overheating the motor. When I got home and flushed the motor I looked carefully and saw there was still water coming from the exhausts next to the leg mounts (sorry I don't know their proper name) but now also a constant stream out of the open bung hole. Both were warm from the engine. The motor did not run any hotter, again and I checked all hoses I could reach and all looked new and plyable (not old and stiff). I felt where the hoses come out of the heads and no leaks there, up to the thermostat housing and then out to exhaust elbows and no leaks. I'm guessing somewhere after there and before the transom is a leak that I can't see emptying into the bilge.
I want to know what next as I'm now shore bound as I don't want to risk anything more serious until I sort it out. My guess is all plumbing etc is original from 2006 and probably is due to be replaced anyway but don't know where to start. I'm also guessing its easier to remove the whole motor to do this and check other things while I'm at it?
Any help is greatly appreciated as I'm now search for service manuals.
Cheers Whitey
Cheers Whitey
