'05 50 HP Johnson. With VRO pump/VRO pump wiring pigtail delete. I get the system check beep and the lights countdown on the tach with initial start up. With temp sensor grounded on head I get the hot warning light on tach but no warning tone from new radio shack buzzer. On the wiring harness to the back of the tach there is a capped purple(switched accessory hot) and a capped white wire. What is this white wire? Tilt/trim gauge sending unit? Any help would be appreciated.
