Can someone tell me how to test the warning alarm on the remote control? It is on a 1994 Evinrude 112 SPL. I looked through diagrams and through the service manual, but it doesn't get specific(or at least I can't find it). The alarm box has a black wire coming out that is grounded. It has two tabs on it. On tab has a tan wire on it. That goes to the temp switches. The other tab has two purple wires on it. One wire goes to the ignition switch, and I am not sure where the other goes. I assume if the purples have powers and you ground the tan wire tab the alarm should sound? Every once in a while when I would turn the key on to start the alarm would sound for a second. I know that is a self check, but it doesn't do it all the time. What makes it self check? How do you know if the self check is working?
Also I read about 60 degee and 90 degree motors and loopers and crossflows. Which is this motor?
