Warning Buzzer Does Not Work
bamadave
'96 Mariner 200 EFI
Last year I disconnected the oil pump because the drive failed. I installed the blockoff kit. I was told the warning horn would still work for the temp and water in the fuel filter but they don't work. I'm grounding the beige wire hooked up to the temp sensor and the sensor on the bottom of the fuel filter. Any suggestions where to start looking as to why the horn doesn't sound? Thanks Guys
Don S
Re: Warning Buzzer Does Not Work
Check the buzzer itself.
bamadave
Thanks Don, I'll check it and let you know. Thank You!
