johnrmclean
- Joined
- Jun 12, 2007
- 81
[h=2]Warning Buzzer Problem 1994 Baja 272 .. 454 Mercruiser[/h]
Down to my last issue hopefully. Not totally new. Got everything running fine. Engine runs cool. Temp gauge works ..holding under 100 degrees using muffs, exhaust manifolds just warm . No smoke or oil burning. Oil pressure gauge reading good.....
BUT..at start the warning buzzer goes on and will not go off. Ran for 10 minutes and did not go off. Then after I shut down the engine and started it back up after a minute or so buzzer did not go back on. Anyone know whats up with that??
Manual says the buzzer is for three things .. H2o in cooling system too hot..not buzzed from start up .. engine oil pressure too low.. good pressure ..running about 40 psi after start up... trans fluid too hot ... no trans so not an issue ..
