98 bayliner mercruizer 5.7l carb. my buzzer would always beep when i turned on the key. today was raising my outdrive and turned on the key while raising it to watch the trim gauge. now the thing buzzes as soon as i turn on the key until the engine fires. its a very loud and piercing alarm and is gonna make me deaf
does it warm or cold. checked oil res and oil pressure is same as it always has been. once engine fires it stops and i'm at peace again, any ideas???
the tach stopped working last time out, checked wiring at the coil and back of gauge and all is hooked up as it should, from the wiring diagram it looks as if all the gauges use a common hot wire. any ideas on this one???
