Simoniz
- Joined
- Dec 30, 2007
- 242
I was poking about behind the dashboard of my Bayliner 175 (2000 year) today and saw that there was a warning buzzer fitted. Its hanging from a cable tie and is connected with bullet connectors to the wiring loom with a mauve wire and a brown / blue wire. The wires in the loom are the same colour which makes me think its original and not been added by someone.
The wiring diagram in my manual shows an alarm buzzer which is activated by either overheat, low oil pressure or low drive lubricant level but Ive never heard the buzzer sound, even before the engine is started, as you might expect for the oil pressure case.
Since the oil press and water temp are electronic instruments, the buzzer could be wired up but Im pretty sure theres no sensor for the drive lube level.
Is this buzzer standard with my boat? Can I get it to work?
