Boatingdobbins
- Joined
- Jul 13, 2001
- 27
Looking for some troubleshooting help with the above motor. Shortly after starting the motor the warning horn went off. I had 10 psi of water pressure and a good stream of water. The heads did not feel overly hot, but I did not test with a heat gun. I disconnected the temperature sensors located in the head and the horn continued to go off.
Prior to starting the engine, I had a hard time getting the priming ball to pick up fuel and get hard. While troubleshooting, I ended up re-prime to re-prime the bulb and the horn problem went away?
Does the horn go off on low fuel pressure also? Last year when winterizing I decided to run the gas out of the engine and remember the horn going off VRO also. The VRO system is disconnected.
Any help would be appreciated.
I n
I n
