Hello I have a 140hp Suzuki outboard and need some help.
I replaced my battery's in my boat and now my waring lights and buzzer wont run a test when you first turn the key on and my trim tilt gauge wont work also
My tach still works fine I check the battery connections and looked for a loose or missing wire but everything is fine. I also check what fuse i did see not sure if there are hidden one's i didn't see.
any help would be great.
Thanks
BadBoy
Thanks
BadBoy
